		2021-01-29
		10:53 PM
		2023-05-23
		12:09 AM
			Gordana Radonic
Solved! Go to Solution.
2023-08-03 12:28 PM
Hi all,
This appears to be the result of a bug, DEF-4010, that was fixed in Archicad 25 Update 4, Archicad 26 Update 2 and Archicad 27. The Model View Options went missing if the dialog was not reserved before making changes.
Although the issue has already been fixed (make sure you're on the latest update), a project that was created in a buggy version would continue to have the missing MVO. It may be best to reshare the project with the latest update and re-assign the MVOs.
I sincerely apologize for the inconvenience caused by this issue.
Kind Regards,
Oleksandra Vakariuk
Technical Support Engineer
2021-02-01 01:40 AM
Red wrote:
I am having a recurring issue with my template file. I have every view set and saved the way I need it, but after saving it and reopening to add or change items, each view will state,"Missing (Floor Plans)"in within the View Settings. I open the "View List" under "Project Indexes" and everything is good there so I thought it was just a visual glitch.
2021-02-01 02:28 AM
2021-02-01 02:39 AM
2021-02-01 02:48 AM
2021-02-01 12:51 PM
2021-02-01 01:20 PM
Minh Nguyen
GRAPHISOFT
2021-02-01 05:13 PM
2021-02-01 10:45 PM
mnguyen wrote:The solo .pln worked normally, and all MVO settings stayed that I reset on 3 separate PCs.
Thank you very much for your report and I am very sorry about the issue!
As you reported that the file is stored on BIMcloud, I'm wondering if you save it as a solo file and work on it locally, will the issue occur again? This is very important for us, in order to know whether this is BIMcloud or Archicad related issue.
Best regards,
Minh
2021-02-02 01:22 AM
