‎2021-01-29
10:53 PM
‎2023-05-23
12:09 AM
Gordana Radonic
Solved! Go to Solution.
‎2021-02-24 07:15 PM
mnguyen wrote:Any updates on this issue. It appears to be BIM related only. If I noticed another pattern, I will let you know.
Thank you very much for your report and I am very sorry about the issue!
As you reported that the file is stored on BIMcloud, I'm wondering if you save it as a solo file and work on it locally, will the issue occur again? This is very important for us, in order to know whether this is BIMcloud or Archicad related issue.
Best regards,
Minh
‎2021-02-25 03:16 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2021-02-25 05:58 PM
mnguyen wrote:As for the renaming, some were renamed, and I was curious myself if that was the issue, but I did go back through and correct them; however, they revert back to missing once it is closed and reopened.
I am very sorry for the late reply! Somehow this thread does not give me an email notification so I missed your previous answers!
It is a bit difficult now as the issue only appears in Teamwork environment. What is very strange to me is why the Project Indexes list the view without any missing settings, but the View Settings itself reports otherwise.
Is there a way to reproduce the issue? Does it happen with all of your Teamwork projects or only with certain projects? Some screenshots would be very helpful for us to understand the situation better.
Also, I would like to draw your attention to a new feature since Archicad 23 (although I don't think it might be the case, but just to make sure): In previous versions, if you renamed Layer Combinations, MVOs, Pen Sets, Renovation Filters, Graphic Override Combinations, Dimension Standards or 3D Styles, then any Views referencing these would display them as “missing” in View Settings – because the link was based on the settings name. As of Archicad 23, a unique identifier is used so these settings no longer go missing after a rename.
Best regards,
Minh
‎2021-02-25 06:13 PM
‎2021-02-25 06:17 PM
‎2021-02-28 09:50 PM
scraptrash wrote:Are you also using BIM Cloud Basic?
I have the same issue too.
I didn’t have time to report it though.
‎2021-03-02 03:17 PM
Minh Nguyen
GRAPHISOFT
‎2021-03-03 03:57 PM
mnguyen wrote:
Hello Red,
Thank you very much for your finding! This is very strange indeed...
It would be great to know if there is a way to reproduce the issue from scratch? Also, does it happen with all of your Teamwork projects or only with certain projects? If you start a new one, will the MVO also go missing after some modification/send&receive?
I am very sorry that I cannot be more specific, but without a way to reproduce the issue, or at least narrow down which projects are having the problem, it would be very difficult for us to investigate further.
Best regards,
Minh
‎2021-03-04 10:50 AM
Minh Nguyen
GRAPHISOFT
‎2021-03-04 11:52 AM
mnguyen wrote:Yes, I will work on that this morning once I get to work.
Dear Red,
Thank you very much!
If that's the case, I would like to have a sample project of yours, with which we can reproduce the issue in-house.
Could you please try to reproduce the issue on one of the projects and create aTeamwork Support Package? I will send you a special link with which you can upload the package to us for further investigation.
Thank you very much for your help!
Best regards,
Minh
