2024-05-21
11:24 PM
2024-05-26
10:50 AM
My model will not stay feet and fraction. It keeps changing to decimal and is not consistent from dimensioning a elevation.
the saved format does not stay. Even though I tell it no fractions it still creates decimals.
Operating system used: Windows 5003
2024-05-21 11:53 PM
Check whether the Dimensions in the View Settings are correctly applied in all views and whether they have been saved.
Regards.
2024-05-21 11:54 PM
They are replied properly and change on their own. the changes are not sticking
2024-05-23 03:41 PM
The work then change back almost immediately. the changes do not stick If I use the terminology correctly - there is only one Screen bur plans and sections and elevations.
right now I am modeling and dimensioning the plan and the dimensions either change almost immediately back to decimal or do when I save and exit and reopen.
I do not know where to go from here as I tried to reach tech and nothing but an email on what it cost for support. I think this is more a misbehaving software than a help for how to place a dimension.
2024-05-24 03:20 AM
I have already adjusted the setting and they will stay for a minute or few and will revert back - as if they are stuck in metric with imperial as a mix. I have already done as you suggested probably 50 times.
2024-05-24
03:33 AM
2024-05-26
10:47 AM
Can you show a screen image of your dimension style settings, showing the settings for the fractional dimensions.
Like this for example...
Then also a screens image of the view settings so we can see if the correct dimension style is applied.
Also a screen shot of you wrong dimensions when the correct dimension style is applied.
