Eric Milberger
Mixture of decimal and and fractional dimensions
My model will not stay feet and fraction.  It keeps changing to decimal and is not consistent from dimensioning a elevation.
the saved format does not stay.  Even though I tell it no fractions it still creates decimals.
Operating system used: Windows 5003
Eric Milberger, Architect | Master Planner
5 Replies 5
Ricardo Lopez
Hi @Eric Milberger
Check whether the Dimensions in the View Settings are correctly applied in all views and whether they have been saved.
Regards.
Ricardo López, M. Arch.
Eric Milberger
They are replied properly and change on their own.  the changes are not sticking
Eric Milberger
The work then change back almost immediately.  the changes do not stick If I use the terminology correctly - there is only one Screen bur plans and sections and elevations.
right now I am modeling and dimensioning the plan and the dimensions either change almost immediately back to decimal or do when I save and exit and reopen.
I do not know where to go from here as I tried to reach tech and nothing but an email on what it cost for support.  I think this is more a misbehaving software than a help for how to place a dimension.
Eric Milberger
I have already adjusted the setting and they will stay for a minute or few and will revert back - as if they are stuck in metric with imperial as a mix.  I have already done as you suggested probably 50 times.
Can you show a screen image of your dimension style settings, showing the settings for the fractional dimensions.
Like this for example...
Then also a screens image of the view settings so we can see if the correct dimension style is applied.
Also a screen shot of you wrong dimensions when the correct dimension style is applied.
