2015-09-16
10:55 PM
2025-02-07
12:04 PM
Aruzhan Ilaikova
2015-09-17 03:16 AM
2015-09-17 03:20 AM
Barry wrote:
The only way I know of is to place the walls in different layers that have different intersection priority numbers so they don't join with each other.
So duplicate your wall layer and make sure it has a different IP number to the original.
Make sure this new wall layer gets turned on in all the layer combinations that the original layer is turned on for.
2015-09-17 01:40 PM
2015-09-17 02:03 PM
David wrote:But is that because you have the 'Clean wall & beam intersections' option turned off?
Have you tried Wall Settings > Floor Plan and Section > Outlines > Wall End Lines (Both, Start, End, None)? Works here in AC19.
2015-09-17 04:15 PM
2015-09-17 04:16 PM
Barry wrote:David wrote:But is that because you have the 'Clean wall & beam intersections' option turned off?
The reference lines and end lines will show as in your image when this option is turned off.
I have both wall ends on and I don't see them on joining walls in 19 either unless I turn that option off or use 2 layers with different intersection priority numbers.
2015-09-17 04:23 PM
rob2218 wrote:VIEW menu > On Screen Options.
where is this "clean wall and beam intersection" setting?
Also...will it not then cleanup the walls it's suppose to clean up?
2015-09-17 04:25 PM
Barry wrote:rob2218 wrote:VIEW menu > On Screen Options.
It will stop all wall and beam connections so you corner junctions will not trim.
2015-09-17 05:14 PM
