New and Existing - how to show "end" line when end to end
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-09-16
10:55 PM
- last edited
a month ago
Aruzhan Ilaikova
we need to indicate that "end" line condition to distinguish when "new" meets "existing".
I cannot change the justification of the wall planes either...they MUST have the same reference line (the framing skin).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
- Labels:
Lines & Arcs & Circles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 03:16 AM
So duplicate your wall layer and make sure it has a different IP number to the original.
Make sure this new wall layer gets turned on in all the layer combinations that the original layer is turned on for.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 03:20 AM
if you miss ONE and only ONE layer combo, low and behold THAT will the be the layer combo the bossman says...."you messed up".
Geez....if there was only a way to just tell the ends of the new walls to distinquish themselves from the ends of the "existing" walls or vice versa.
Barry wrote:
The only way I know of is to place the walls in different layers that have different intersection priority numbers so they don't join with each other.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 01:40 PM
Have you tried Wall Settings > Floor Plan and Section > Outlines > Wall End Lines (Both, Start, End, None)? Works here in AC19.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 02:03 PM
David wrote:But is that because you have the 'Clean wall & beam intersections' option turned off?
The reference lines and end lines will show as in your image when this option is turned off.
I have both wall ends on and I don't see them on joining walls in 19 either unless I turn that option off or use 2 layers with different intersection priority numbers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 04:15 PM
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 04:16 PM
Also...will it not then cleanup the walls it's suppose to clean up?
Barry wrote:David wrote:But is that because you have the 'Clean wall & beam intersections' option turned off?
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 04:23 PM
rob2218 wrote:VIEW menu > On Screen Options.
where is this "clean wall and beam intersection" setting?
It will stop all wall and beam connections so you corner junctions will not trim.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 04:25 PM
I just need the "ends" to not clean up when a "NEW" wall meets and "EXISTING" wall.....you'd think it be some setting pretty obvious but I can't seem to locate where that is.
Barry wrote:rob2218 wrote:VIEW menu > On Screen Options.
i>u
Edgewater, FL!
SOFTWARE VERSION:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-09-17 05:14 PM
