New and Existing - how to show "end" line when end to end
rob2218
see attached.
we need to indicate that "end" line condition to distinguish when "new" meets "existing".
I cannot change the justification of the wall planes either...they MUST have the same reference line (the framing skin).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
26 REPLIES 26
The only way I know of is to place the walls in different layers that have different intersection priority numbers so they don't join with each other.
So duplicate your wall layer and make sure it has a different IP number to the original.
Make sure this new wall layer gets turned on in all the layer combinations that the original layer is turned on for.
rob2218
Yeah....that's a hangup.
if you miss ONE and only ONE layer combo, low and behold THAT will the be the layer combo the bossman says...."you messed up".
Geez....if there was only a way to just tell the ends of the new walls to distinquish themselves from the ends of the "existing" walls or vice versa.
i>u
Edgewater, FL!
SOFTWARE VERSION:
David Maudlin
Bobby Hollywood:
Have you tried Wall Settings > Floor Plan and Section > Outlines > Wall End Lines (Both, Start, End, None)? Works here in AC19.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
But is that because you have the 'Clean wall & beam intersections' option turned off?
The reference lines and end lines will show as in your image when this option is turned off.
I have both wall ends on and I don't see them on joining walls in 19 either unless I turn that option off or use 2 layers with different intersection priority numbers.
rob2218
Yes, I too have the "both" wall ends on...and I get nothing as well.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
where is this "clean wall and beam intersection" setting?
Also...will it not then cleanup the walls it's suppose to clean up?
i>u
Edgewater, FL!
SOFTWARE VERSION:
VIEW menu > On Screen Options.
It will stop all wall and beam connections so you corner junctions will not trim.
rob2218
Geez....well that's not good.
I just need the "ends" to not clean up when a "NEW" wall meets and "EXISTING" wall.....you'd think it be some setting pretty obvious but I can't seem to locate where that is.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stephen Dolbee
I just draw a line
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
