We value your input!
No IFC in Labels in 19
The labels in 19 could not read and display the IFC, which I used to insert my defined value. Any solution?
5 REPLIES 5
Compared with labels in 19, the generic label 18 could display any IFC of object as shown in Figure 02.
Eduardo Rolon
I think that this was moved to the "Tags and Categories"Label.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
It really is! Thank you very much!
FYI:
In ARCHICAD 18 and earlier each element could have only one Label. Because of this limitation, the "Generic Label 18" object was the label you had to use to list all kind of parameters, including IFC Properties.
In ARCHICAD 19 each element can have as many Labels assigned to it as needed. Because of this the functionality present in the "Generic Label" object could now be distributed into multiple label objects. Usually the name of the label gives a good idea of its intended use, such as "Tabs and Categories Label", "Surface Label", "Skin List Label', etc.
Link
Please also check out a blog post I wrote on IFC Properties in Labeling and Scheduling on the BIM6x Blog for ArchiCAD.
Link.
