SOLVED!
No cabinet opening lines after updating to 27.2
figge
Hi all,
Since updating to AC27.2 all the swing lines seems to have disappeared from joinery items on all Internal Elevations....anyone seeing the same thing or have any ideas...?? I'm using the standard AC27 library objects (Standing Cabinet Block 27).
Attached image shows before and after....
Operating system used: Windows 10 Pro
W10 Pro | ArchiCAD 29.0.0 (3000) AUS FULL | Twinmotion 2025.2
1 ACCEPTED SOLUTION
Solution
Got it..!!!
Had to actually delete the ArchiCAD 27 library in the Library manager and relink it (in the default location) for it to pick up the settings.
Don't know why it had disappeared as ArchiCAD Library 27 and all objects were loaded.
Back to normal....thnx Barry!
5 REPLIES 5
It is a Model View Option setting - same as before I believe?
Thats what I thought it might have been but seems as though I don't even have that option any more...
Only change that was done to the setup of the file was the update to 27.2.0.
Solution
Got it..!!!
Looks like you had an addition version 17 library loaded?
cleaned up...
Setup info provided by author
