Orientation of Vectorial or Symbol Fill to a slab in section
Hi there! New to Archicad here, so apologies if this question is eye-rolling simple... I modelled a floor build-up, using the slab tool to create the horizontal surfaces such as floor boards and insulation, and the beam tool for beams. I then drew a section cutting through it. I now go to the section and I notice that the fills for the materials aren't orientated correctly: the insulation fill for example is partially displayed, and appears too large. So I click on the relevant object, which was modelled as a slab. Where do I edit how the section fill appears for this slab?
I came across this https://helpcenter.graphisoft.com/user-guide/65480/ but this seems to apply only to a plan view? Or am I missing something glaringly obvious?
5 Replies 5
Could you please post one or two screenshots that show exactly how those fills look now?
Hi, I have attached a screenshot of the section view.
I have a workaround, which is to use a 2d object and place it in the section view, but this seems like unnecessary extra work!
The trick is to use a Building Material that has the "Fit to Skin" Fill Orientation option specified for its Cut Fill. Then it will automatically adjust itself to the width on the skin.
Please note that the "Fit to Skin" option is available only when a Symbol Fill is specified for Cut Fill.
Aha! Ok thanks! So I made sure the relevant insulation fill had the "Fit to Skin" orientation selected. But this made no change as I had the slab modelled as a basic slab... So then I created a new composite slab type just for the insulation, and set the insulation thickness to what is required. I then modelled the insulation as a composite slab with the new composite slab type, and it looks like I need it to. Thanks for your help!
Yes, sorry, I forgot that this works only in composite structures and complex profiles.
