‎2005-10-04
03:52 PM
‎2023-05-26
02:36 AM
Gordana Radonic
‎2005-10-04 04:25 PM
Daniel wrote:Try <DrawingScale> instead.
I have a problem with my autotext feature not working in PlotMaker, I've had this problem before and just did a work around by manually writing in the scale on the layout. This is really not acceptable in this instance though, as the scale changes between sheets, and I don't have time to do it manually (nor do I want to, since I shouldn;t have to) It's probably something simple I'm overlooking, or possibly not undesratnading... but any help would be appreciated
cheers,
dan
‎2005-10-04 06:52 PM
‎2005-10-04 07:19 PM
‎2005-10-04 10:39 PM
‎2005-10-05 03:13 PM
Djordje wrote:If I do this the scale does come out correctly, but I don't understand why it should make a difference, why can a drawing title, which is presumably pulling the output scale using the same function call as the auto text <OUTPUTSCALE> feature, come out with a different result... it just doesn't make sense to me. Also, even though this does result in printing the right scale, my bosses are picky about using their title block
Only one or more drawings per sheet?
If more, set the titleblock scale to As shown @ sheet size, and use the drawing titles with DrawingScale (or, safer and always correct) OutputScale - per drawing.
