Output scale autotext issue
I have a problem with my autotext feature not working in PlotMaker, I've had this problem before and just did a work around by manually writing in the scale on the layout. This is really not acceptable in this instance though, as the scale changes between sheets, and I don't have time to do it manually (nor do I want to, since I shouldn;t have to) It's probably something simple I'm overlooking, or possibly not undesratnading... but any help would be appreciated
cheers,
dan
5 REPLIES 5
TomWaltz
cheers,
dan
Try <DrawingScale> instead.
Tom Waltz
Actually, I get the same thing.. this is weird..
also, the scale is set to 3/16" = 1'-0" in the viewsets....
Djordje
Only one or more drawings per sheet?
If more, set the titleblock scale to As shown @ sheet size, and use the drawing titles with DrawingScale (or, safer and always correct) OutputScale - per drawing.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
when I put both scale to output scale, and scale to drawing scale. They both say the same thing even though I print to 1/2 size sheets. Is this a plot only issue, or can we print ledger size paper at 1/2 scale, and have the scale be accurate. Am I missing some setting on the Title block?
Thanks
If I do this the scale does come out correctly, but I don't understand why it should make a difference, why can a drawing title, which is presumably pulling the output scale using the same function call as the auto text <OUTPUTSCALE> feature, come out with a different result... it just doesn't make sense to me. Also, even though this does result in printing the right scale, my bosses are picky about using their title block
cheers,
dan
