PDF Prints - Flattened Images
Is there a way to flatten the PDF image (a la photoshop) we printing to a PDF file. When I open my PDF files created from AC, it redraws all the lines, fills...etc. even those covered up by other elements/fills.... mimicking the draw order layering of the actual model. I can only imagine how much all these unseen elements add to the overall file size and redraw time. I know in photoshop we can "flatten" an image which greatly reduces the file size, is there any way to print/publish to PDF in a similar manner? If not, then I know the next wish list item I will be posting.
5 Replies 5
Djordje
Open in Acrobat (full, not Reader), Reduce file size ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Eduardo Rolon
In Mac open in Preview and do the same.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I know how to do this with Acrobat but I don't see a command for it in Preview. Where is it located?
Eduardo Rolon
File -> Save As
in the Quartz filter select -> Reduce File Size
If you need to create a New filter open ColorSync and select the "Filters" Tab.
AC29 US/INT -> AC08
ejrolon wrote:
File -> Save As
Thanks. Always something new to learn here at ArchiCAD Talk.
