PDF Trace Reference at wrong scale
So I have an empty Layout sheet with the survey PDF on it (I do this with my engineers drawings). Now I want to use that survey, which is drawn at 1:20 scale as a trace reference on an enlarged grading plan (1/8" scale), but I cannot get the scale of the PDF to match that of the enlarged grading view map.
Any idea how to accomplish this?
Eduardo Rolon
1. Create a New Worksheet
2. Set the scale of the Worksheet to match the PDF (in this case 1:20)
3. Place the PDF (using the place drawing command not copy/paste from the Layout) in the Worksheet
4. There is no step 4
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
yay, it worked this time!!
I swear i tried that, but it didn't work.
Its working now, thank you!
