I do not have an issue with speed, the previous poster does. My issue is with filesize, which is atypical for a vector quality architectural ArchD sheet. Typically we print publish 20 sheets in well under 5 minutes.
When firms are printing hundreds of sheets, the problem with filesize becomes a serious problem, as you can well imagine. Longer generation time may be because in the latests builds, AC updates placed drawings that are set to 'automatic' (well, at least for publishing DWGs it does)
Andy Thomson, M.Arch, OAA, MRAICDirector
Thomson Architecture, Inc.Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
