β2003-11-22
12:53 AM
β2023-05-26
02:39 AM
Gordana Radonic
β2003-11-22 12:54 AM
β2003-11-22 12:59 PM
Jay wrote:Don't copy & paste. Import the PMK.
Warning Error Attachment
β2003-11-22 06:44 PM
Djordje wrote:I am Importing the Original PMK, Then I usually Copy and paste. I will try the Ctrl Drag to the Navigator.
Its size is too big for the copy&paste operation.The Size of the "improted" PMK's never was an issue before. They would always copy and paste. The also would zoom all correctly. Now with PM 3.1 and an imported PMK (note PMK is from AC 7.03, as I have always done in PM 3.0) somehow has a Tile Type
If it is in the same LBK, CTRL drag it in the Navigator. Or copy&paste there.It is the same LBK, no copy & paste allowed.
You can also drag&drop from PM 2.3 or 3.0PM 2.3 is a joke.
β2003-11-22 07:30 PM
Jay wrote:Titles are on by default; you can switch it off in Preferences.
The Size of the "improted" PMK's never was an issue before. They would always copy and paste. The also would zoom all correctly. Now with PM 3.1 and an imported PMK (note PMK is from AC 7.03, as I have always done in PM 3.0) somehow has a Tile Typelinked to it. This template lbk did not have this happen in PM 3.0.
One thing that does remain a problem from PM 3.0 is Linked PMK's Missing information I asked this question back in escribeMy answer is there too.http://www.escribe.com/software/archicadtalk/m33088.html
I will ask this as a new topic on this Forum.
Seehttp://archicad-talk.graphisoft.com/viewtopic.php?p=3495#3495
It is the same LBK, no copy & paste allowed.No need to - drag, CTRL drag.
I will consider going back to PM 3.0. Since I totally uninslatted any previous remnants of the AC 8.0 release, I quess I will have to re-install AC 8 R3. See any problems?No, also I don't see any reason to do so. 3.1 is better, takes some time to set it up. Keep the nose to the grindstone. Usually pays if you can stand it
β2003-11-22 09:29 PM
The preferences state "Append Titles to newly placed Drawings." This does not seem to count for newly updated Drawings (or PMK's). After changing preference and reading all from folder again and updating, the zoom all is still "broken".
As for the wrong zoom/PMK extents, I also had some problems with the PMK frames being MUCH larger than they really are.Do you mean the Extents (node drag points) that can be changed upon dragging?
It is the same LBK, no copy & paste allowed.Actually a copy paste from on layout to another just worked
Djordje: No need to - drag, CTRL drag.![]()
But as for a drag - Ctrl drag, I finally figured out that this was in "Tree by Subsets" mode.Probably in Mannual.
No SpellCheck
β2003-11-23 01:49 AM
β2003-12-07 10:22 PM
β2003-12-08 10:30 AM
β2003-12-08 12:33 PM
david wrote:Pilot error, David.
I am concerned that I cannot change the scale of PMKs brought into Plotmaker 3.1 from AC 8.1 (windows XP, AC 8.1).
