PM9 to PM 3.1
Is it my imagination, or is it not possible to go backwards from v9 Plotmaker to v3.1 Plotmaker?
6 REPLIES 6
Not your imagination! For some reason this was left off. However I have left v3.1 in the dust and moved completely to AC9.
Aaron Bourgoin
PM 9 appears to be able to read AC8.1 models just fine. Is that what you wanted to do?
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.1 USA
Rhino 8.25 Mac
MacOS Tahoe 26.1
As far as I remember it has never been possible to save a file form a certain version of Ac or PM and read it with an earlier version of the same software.
The only exception is when you save from ArchiCAD in the format of an earlier version, but even in that case library parts and created with and elements available in the later version will not go through.
Djordje
It is not.
Why do you want to do it?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hi Djordje,
The reason for needing to being able to save a 9.0 version Plotmaker File as a 3.1 is the same as saving a 9.0 Archicad file as an 8.1 version - to exchange files with Archicad users who have not yet upgraded to version 9.0.
I too have found it very frustration that this capability exists within Archicad, but not in Plotmaker.
Don
Haneef Tayob
Hello
Not sure about the legal items (and definitely don't want to support piracy, especially of a decent program such as Archicad/Plotmaker). I vaguely recall that in the earlier versions of Plotmaker, there wasn't really a restrictions on the number of installations one could make of the software. If allowed, a user of Archicad 8.1 could be using Plotmaker 9.
As I said "vagely" - I'm not sure if it was the case and is still the case.
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
