ā2013-08-22
12:57 AM
ā2023-05-19
10:13 PM
Gordana Radonic
ā2013-08-22 03:03 AM
ā2013-08-22 03:07 AM
ā2013-08-22 04:26 AM
Barry wrote:Thanks for your response, Barry.
Sorry no answer for you but have you tried publishing as separate PDFs rather than combining into one file?
It would be interesting to see if it creates a zero size file.
ā2013-08-22 04:28 AM
Kristian wrote:Thanks, Kristin.
Dennis
I've had similar issues with certain fills (they were created in V6 ish) that have thrown out the PDF publishing process.
On the 2 layouts that are not publishing, recreate the same views but in the model view options for the views set all the override fill display options to no fill.
Then republish the set. If the layouts with issues publish you then have to start the fun game of hunting down the problematic fills!
Hope that helps
ā2013-08-22 04:31 AM
ā2013-08-22 04:35 AM
ā2013-08-22 04:59 AM
Barry wrote:I eliminated the non-printing GIF problem by changing the signature file format to JPG, and now the signatures print.
Anything to do with the GIFs you mentioned in another post?
ā2013-08-22 05:04 AM
Barry wrote:What I eventually did was to batch print the PDFs as separate files. I was able to print the ones that weren't saved in the batch printing did individually, as separate files.
Maybe select each page separately and "Publish selected items" to see if you can narrow it down to a particular page that just won't print.
As it seems to be a random page that doesn't print try and see if a single page on its own will or won't print.
ā2013-08-22 05:19 AM
