PUBLISHER SKIPPING PAGES
DennisG
I'm trying to print out a PDF set of layouts, 30"x42", 19 sheets total and am noticing a scary bug.
Every time I publish, I notice that one or two sheets are shown as saved, but with no size shown in the "Publishing" list.
- Opening the PDF set shows that the saved sheets of no size are not in the set - even though "Publishing" shows "19/19 done".
- The sheets not saving change every time Publisher is run.
I'm printing to 600 DPI, combining PDFs to a single file.
I've tried exiting out of ArchiCAD, restarting ArchiCAD, reopening the file - with the same results.
I've run Publisher over ten times, with the same result - one or two sheets being left out.
I'm using the latest build of ArchiCAD 17, updated early July.
Help!
Thanks,
Dennis
Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
11 REPLIES 11
Was there any odd characters in layout name Barry?
I had a file that had the | (pipe) in the layout name and it worked half the time but the other half windows decided it didn't want to!
Nope, I typed exactly what was there before.
The strangest character was an underscore.
Must have been an invisible character because I couldn't see anything strange.
Attached is an image of the original name.
