2024-06-13 03:00 AM
So this is what I see on the layout...perfect (bitmap with 2d overlay of fill/lines etc
and this is the published PDF
Why???
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
2024-06-13 03:44 AM
Some odd interpretation of an alpha channel that creates the white space over the blue? Is the map a flat image?
2024-06-13 05:50 AM - last edited on 2024-06-13 06:01 AM by Barry Kelly
I accidentally hit solution...not sure how to revert (EDIT: fixed)
No, its a pasted PNG...no alpha involved
Mark Wesse
2024-06-13 06:44 AM
.png file can contain an alpha channel. Try opening your image in an editor and saving it out as a .jpg
2024-06-13 07:31 AM
I only use lossless formats...but Ill try out of ps as another non alpha for testing. I have always done this so not sure what has changed
jpg is of no value in terms of size as its always represented internally in a full colourspace as you probably know eg jpg saves out small but all progs use it uncompressed.
Mark Wesse
2024-06-13 09:22 AM
More just to test, as .jpgs are flat.
2024-06-13 10:52 AM
Well it seems you cant set 'transparent'...causes the issue. Hmm when are we going to get overlay controls in layout book...only asked for it about 15 years ago...hehe
Mark Wesse
