PUBLISHING: Why are there colour diffs from layout > published
Aurasphere
So this is what I see on the layout...perfect (bitmap with 2d overlay of fill/lines etc
and this is the published PDF
Why???
Mark Wesse
AC26 | Win10 | Since v6.5r
Architerion - Architectural Systems Developer
Aurasphere - Acoustics
Building Biology - Human Compatible Architecture
"--- Every time...do it better ---"
6 REPLIES 6
Lingwisyer
Guru
Some odd interpretation of an alpha channel that creates the white space over the blue? Is the map a flat image?
I accidentally hit solution...not sure how to revert (EDIT: fixed)
No, its a pasted PNG...no alpha involved
Mark Wesse
.png file can contain an alpha channel. Try opening your image in an editor and saving it out as a .jpg
I only use lossless formats...but Ill try out of ps as another non alpha for testing. I have always done this so not sure what has changed
jpg is of no value in terms of size as its always represented internally in a full colourspace as you probably know eg jpg saves out small but all progs use it uncompressed.
Mark Wesse
More just to test, as .jpgs are flat.
Well it seems you cant set 'transparent'...causes the issue. Hmm when are we going to get overlay controls in layout book...only asked for it about 15 years ago...hehe
Mark Wesse
Setup info provided by author
