Haneef Tayob
Panning view of placed drawings
I can't figure out how to pan the view of a placed drawing in AC10 as I used to do in Plotmaker 9.
Would appreciate it if someone could briefly explain it to me (if it is still possible)
In AC10, If I want to move the plan around a bit on the layout, I have to use the 'offset edge' with 'drag' a few times which is a few steps more than in AC9 and is a pain if you have a few cropped off portions of drawings on one layout.
Hope I'm clear in the request.
Thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
5 Replies 5
Erika Epstein
Are you sure you mean PAN?
Are you are trying to reposition a drawing on a layout or adjust the frame of the drawing?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Ted Taylor
When the placed drawing is selected, there is a dot in the middle and the four corners of the drawing. Select the middle dot and the PET palette will give you the option that I think you are looking for.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Yes it does, Ted. Well spotted. Only problem is you don't get a ghost image of your drawing so can't see what the result is going to be. Pity.
Haneef Tayob
Thank you very much for the suggestion Ted, it's what I was looking for. I also agree with Stuarts comments.
regards
Haneef Tayob
Or select and use Ctrl D on the keyboard.
