Pdf plot crash
I've a problem with the plot pdf file. The file is almost 13 MB, when I open it with adobe pdf reader, adobe reader crashes because the file is damaged. Is this a problem in my archicad configuration? Every windows computer that's trying to plot this file, has the same problem. On the other hand OSX has no problems, that pdf plot is just a few mb.
Is there a solution for this problem?
1 REPLY 1
Are you using AC's >Document >Publisher to create the PDF or are you using the > File >Print function?
Snap
