2013-11-18 12:41 PM - last edited on 2023-05-26 02:28 AM by Gordana Radonic
2013-11-18 02:45 PM
2013-11-18 02:54 PM
2013-11-18 08:31 PM
2013-11-19 02:30 PM
kielbasa wrote:Model Elements (Walls, Slabs, etc) are real world dimensions. Paper Size Elements (Text, Labels, Dimensions, etc) are not real world dimensions, they are sized according to the scale of the drawing when they are placed. When the scale of the drawing is changed, the Model Elements remain the same size, the Paper Size Elements change relative to the Model Elements for the current scale. The simplest method is to set the drawing scale to the desired output scale before adding Paper Size Elements. If this has not been done then there are two options: 1. Change the pen set to conform to the changed scale or 2. Set the correct scale in the drawing and resize and reposition the Paper Size Elements. #1 is less work, but there remains the disconnect between the drawing scale and the output scale. #2 is WYSIWYG.
But how should I save a new plan with a correct scale? When I change the scale there is a total mess with letters, lines etc.. Could You explain it please?
