2006-05-10 11:27 PM - last edited Wednesday by Molinda Prey
2006-05-16 02:38 PM
2006-05-16 03:25 PM
2006-05-16 03:36 PM
2006-05-16 04:18 PM
Dennis wrote:The multiple pen sets in AC10 will relieve much of the headache of working with multiple sources like MSA and MaxATS, but in AC9 you will want to settle on a standard pen set that works for you. There have been quite a few discussions of this so a search is advisable.
1) What is the best way to set up your pen weights ? - considering the AC9 library objects' predefined colors, as well as other common objects such as MSA detailer. Seems like MSA and MaxATS as well as default ArchiCAD all have different pen setups.
2) Related to the above question, which template / detailer should one start off using? Or am I expected to start off with blank ArchiCAD and build my own?Use whatever template and/or detailer that seems most suited to your practice. You will inevitably be tweaking and adjusting it to your specific needs, but having a good starting point can save you a lot of head scratching.
2006-05-16 07:17 PM
2006-05-16 08:14 PM
2006-05-17 05:20 AM
Mike wrote:By the default pen sets in 10, not any more.
Don't touch pen 91 since this is the default used for white fills.
2006-05-17 06:57 AM
James wrote:
Matthew, I bet you're excited about the pen descriptions in 10.
2006-05-17 07:01 AM
Djordje wrote:Don't remind me!!! AAAAARRRRGGHH.....Mike wrote:By the default pen sets in 10, not any more.
