Placed drawing problem while printing
In quite a few of my PlotMaker layout books I get an error message when I try to print, saying there are problems with placed drawings, and directing me to check the drawing usage pallete, but theres no errors there. This problem doesn't affect anything really, except it's an extra mouse click when I print, but I'd just like to know what is causing this... any one have an idea?
cheers,
dan
5 REPLIES 5
TomWaltz
Usually when I see that it's because a drawing is outdated, but that does not appear to be your problem.
I'm not really sure what else this could be
Tom Waltz
Erika Epstein
If you have library loading errors you will also get that message.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I often get this when I have opened an LBK an not needed to update views (because they are already up-to-date.) If you save your PLN again and re-update your drawings in LBK you won't get the message.
This could be the case, because I know the .pln has library loading errors, I'll take the time to fix this and see if this resolves the issue.
I'll try this option out as well.
This problem really doesn't matter, like I said, but it's just one of those things were I go "why?" and my curiousity gets the best of me, so I have to resolve it
cheers,
dan
Erika is correct. There is a library reference in your .pln file that is incorrect, or broken.
