‎2020-07-07
01:11 PM
‎2023-05-19
03:45 PM
Gordana Radonic
Solved! Go to Solution.
‎2020-07-07 04:44 PM
‎2020-07-07 01:43 PM
‎2020-07-07 02:13 PM
‎2020-07-07 06:50 PM
Mac_the_arc wrote:
2- Is there an equivalent of Revit 'model lines' in ArchiCAD, or are all lines only annotation elements and only applicable to the view they are drawn on?
‎2020-07-08 02:42 AM
‎2020-07-08 09:39 AM
Braza wrote:Can this work backwards? i.e. if I set the view parameters in the layout, can I transfer this to the view itself so I can see the extent of the view?
1. If the text/info is only related with that ViewMap, I would place it inside the ViewMap. If the text/info is general to some set of drawings, I would place it in the Layout. But note that you can freely edit your ViewMap/Drawing Edges on Layouts. You can find help on this here.
Hope this helps.
‎2020-07-08 10:06 AM
‎2020-07-08 10:21 AM
‎2020-07-15 10:18 PM
