Plans layout lines as Background with 3D model, How?
Hi
I want to integrate dwg layout line of the plan as 2D lines seen while playing the 3D model . like in Sketch up can do...How?
13 Replies 13
now after i have it inside..how can I choose only obj refernce 2d lines and move it?
pilgonico wrote:
thanx...succeeded to bring it in...but it doesnt in right postion...how do i move it? the obj 2d drawing?
It is the same as any other object in that you just have to select it in plan or 3D and move it.
The thing is it will only have 4 hotspots to select it by at the corners of the bounding box and another in the exact centre.
You will not be able to snap to any of the lines or intersections in the object though.
However if you open the object script again (CTRL+SHIFT+O) and you press the "2D Symbol" button you can add hotspots to the locations where you would like to snap to.
The lines here are snap-able and editable too.
Then just save again and you will be able to select the object and snap to it wherever you placed the hotspots.
Hotspots.
There is an article that talks about this:
http://helpcenter.graphisoft.com/tips/how-to-superimpose-a-2d-floor-plan-onto-a-3d-model/
