‎2004-04-29
07:46 PM
‎2023-05-26
02:39 AM
Gordana Radonic
‎2004-04-30 09:14 AM
Mark wrote:Your view sets should be the same. If it is, select the same TYPE of views in Drawing usage, Link to ... and show the new PLN/PLA. If you just want to update all, and have some JPGs or OLE objects linked, it gets confused.
Can any one help me understand how to get the "Link To " command to work properly in Plotmaker? I am working on a residental subdivision project. I set up a layout book for the first unit and intended to use it on the rest by linking the drawings to another pln. This does not seem to work. Is there a trick to this. Thanks!
‎2004-05-01 12:43 AM
‎2004-05-02 04:26 PM
David wrote:not always the case! i am a little confused about the differences of the 'link to' and 'read from' options: i think i understand how it should work, however i can see no pattern as to when each option is available on some of the layout books i have been using.
Mark,
The "Link To..." option allows you to change (replace) the individually placed source drawing. If you select more than one drawing in the navigator list the button changes to "Read From..." which allows you to change the source path of all of the selected drawings.
‎2004-05-05 08:03 AM
~/archiben wrote:This is just more BGArchiCAD wonders....It is so funny, isn't it?David wrote:not always the case! i am a little confused about the differences of the 'link to' and 'read from' options: i think i understand how it should work, however i can see no pattern as to when each option is available on some of the layout books i have been using.
Mark,
for example, shift selecting a series of drawings in 'drawing usage' can sometimes be 'link to' or 'read from'. often there is one drawing that is the culprit - deselecting it results in a change from 'link to' to 'read from' for all of the others.
also, a single drawing can sometimes give me the 'read from' option instead of 'link to'.
i understand that these options are also related to whether they are linked to viewsets out of archiCAD, or PMKs, etc., but in my case ALL are linked to archiCAD viewsets. it also doesn't seem to make a difference whether the drawings are in the same viewset, or in different ones . . .
have i confused you yet? anyway. i have a whole series of screenshots that i just need time to collate and annotate to send off to GS.
~/archiben
‎2004-05-05 09:31 AM
~/archiben wrote:Ben, I have always found that upon multiple selection the read from option always appears it the files are from different sources. I bet if you look closely the file you deselect will have a different source to the others.
~/archiben
‎2004-05-05 09:47 AM
Aussie wrote:yet another interesting scenario that I would never encounter in my present postion. John, you are are great benefit to this forum!
As for single files- links to projects and sections will "linkto" while plot and graphic files "read from".
‎2004-05-05 09:51 AM
‎2004-05-05 10:53 AM
Aussie wrote:OK - look closely at the attached. all are details. all from the same viewset in the same archiCAD file.
‎2004-05-05 11:04 AM
