ā2004-05-21
10:41 PM
ā2023-05-26
02:38 AM
Gordana Radonic
ā2004-05-22 09:20 PM
Mike wrote:Did you try printing? Before that, which ArchiCAD and which OS?
Could you please include the HPDesignjet 5500ps Plotter in the supported plotters list in Plotmaker for the next revision. Right now the closest plotter is the HP Designjet 5000. This doesn't match the properties of our plotter exactly. For example when we used our old plotter the HPDesignjet 755cm what you see in Plotmaker is what you got when you printed. The layout would print exactly where it was positioned in Plotmaker. With the 5500ps it is hit or miss and we never know where it will print on the sheet of paper. Thanks a million
ā2004-05-24 03:13 PM
ā2004-05-24 03:26 PM
Mike wrote:We had library parts disappear in plotmaker that was due to library paths not being the same from computer to computer, and BGArchicad would just not generate the parts. Be sure and have your libraries either located on a common server or in a path that is identical to every machine.
Djordje,
We were using V3/R3 but we had a another issue with doors & windows dropping out in plotmaker and were suggested to go back to the earlier version. Unfortunately that still did not help.
