Kamelite
Possible to add a watermark in Archicad?
Is it possible to add a watermark to a PDF file from whithin Archicad? From a personal point of view, it is sufficient With a button I can toggle on and off adding a pre-defined watermark, for instance turned on it adds the Word DRAFT over the entire page.
I can't say that I have noticed such a function, does it exist in AC? If not, is it something I should add to a wishlist?
.Kamelite
Windows 10, Archicad 27,28 and 29
3 Replies 3
Erwin Edel
I use adobe acrobat to add my watermarks.
I think you could put text on your master layouts for this and hide the layer.
I'm not a big fan of layers on layouts (we put EVERYTHING on archicad layer, to prevent oops-monents during stressful deadlines where things get published with parts missing on hidden layers), but it might work.
You can even use auto-text linked to project status etc.
If it is on the masterlayout it will allways be behind whatever you add on layouts (drawings, text etc).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Link
Unless you show the master layout above the layout.
Link.
Erwin Edel
Link.
Learning and learning all the time
www.leloup.nl
