ā2018-08-03
05:21 PM
ā2023-05-26
02:24 AM
Gordana Radonic
ā2018-08-05 09:54 AM
ā2018-08-06 08:44 AM
ā2018-08-06 09:17 AM
ā2018-08-06 10:57 AM
ā2018-08-06 11:01 AM
ā2018-08-06 11:03 AM
ā2018-08-09 12:34 PM
ā2018-08-10 02:50 AM
ā2018-08-10 01:33 PM
Barry wrote:I'm not sure I explained clearly. In my layouts (not masters), I use the master layouts as templates. I place my object on the layout (not the master layout) in the title box. If for whatever reason someone decides they need to change that layout from our A2 master to a A3 master, the object stays where it is which ends up being the wrong place. So I either need to have an object on the master which can be clicked (not possible as far as I know) or set the origin of my layout when switching the master layout to be the bottom right corner.
It might be easier if you can show an image of what you have.
If I set up an A1 master with the origin in the bottom right corner and then change page size to A2, everything stays locked to the bottom right corner.
It doesn't all fit on the page of course because it is now smaller.
