Problem with PDF: White lines inside Solid fill
Burcu Meral
As you can see there are white lines inside solid fills. It is not appearing in print, but it is important to see a clean pdf. Thank you!
Archicad 25.0.0 INT Component
4 REPLIES 4
Botonis
Mentor
I believe this is related to a setting in your pdf viewer. Is this Acrobat....?
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
Foxit. But I also tried in Acrobat and nothing has changed..
Thank you! But it is definitely not a proper solution.  Turning off 'Smooth line art'  increases aliasing as they said.
