Burcu Meral
Problem with PDF: White lines inside Solid fill
As you can see there are white lines inside solid fills. It is not appearing in print, but it is important to see a clean pdf. Thank you!
Archicad 25.0.0 INT Component
4 Replies 4
Botonis
Mentor
I believe this is related to a setting in your pdf viewer. Is this Acrobat....?
hevi
Ace
This issue is discussed here.
Burcu Meral
Foxit. But I also tried in Acrobat and nothing has changed..
Burcu Meral
Thank you! But it is definitely not a proper solution.  Turning off 'Smooth line art'  increases aliasing as they said.
