2022-09-09 10:52 AM
As you can see there are white lines inside solid fills. It is not appearing in print, but it is important to see a clean pdf. Thank you!
Archicad 25.0.0 INT Component
2022-09-09 03:29 PM
I believe this is related to a setting in your pdf viewer. Is this Acrobat....?
2022-09-09 03:33 PM
This issue is discussed here.
2022-09-12 04:43 PM
Foxit. But I also tried in Acrobat and nothing has changed..
2022-09-12 04:45 PM
Thank you! But it is definitely not a proper solution. Turning off 'Smooth line art' increases aliasing as they said.
