Publish PDF without overriding existing file
Narska
Is there any setting that would have archicad not overide an existing PDF with the same name when publishing a new set?
Tomasz Mlynarski
New York based Architect
9 REPLIES 9
Eduardo Rolon
AFAIK No.
If the Auto rename option worked with all Publishing options and it had the DATE autotext then you could use it as a prefix and it might work within the limitations but this is another of the 80% tools.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Narska
This date auto-text thing you mention would likely save me hours over the course of a year... I'm not a programmer but this seems like low-hanging fruit.
ejrolon wrote:
AFAIK No.
Tomasz Mlynarski
DGSketcher
Legend
I am using AC24 on Mac and can add <SHORTDATE> to the end of both custom file & folder names in Publisher which seem to be updating correctly these days. Earlier versions were prone to ignoring the conversion or placing the date as static. Worth a try?
Eduardo Rolon
That doesn't seem to be an option in the US version.
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
OK, writing <SHORTDATE> looks like it might work
AC28 US/INT -> AC08
another Moderator
DGSketcher
Legend
There's a list of system auto texts here... https://helpcenter.graphisoft.com/user-guide/135256/, and yes I think you have to type them in manually.
Eduardo Rolon
and to get a YYYY-MM-DD without the slashes you type:
<YEARLONG>-<MONTHNUMBER>-<DAYOFMONTH>
AC28 US/INT -> AC08
another Moderator
Podolsky
Ace
Yes, not all auto-texts are shown in drop-down menu - you need to type them manually and it works.
Brian Spears
The short date can be configured to YYYY-MM-DD in the System Preferences.
Brian Spears
BIM Manager, Steele Group Architects
Winston-Salem, NC
AC27 USA on macOS
