2020-04-21 08:38 PM - last edited on 2023-05-26 12:12 AM by Gordana Radonic
2020-04-22 02:53 AM
2020-04-22 05:12 AM
2020-04-22 08:31 AM
2020-04-22 08:57 AM
Barry wrote:yes all items - green ticks - saved
So after publishing, all the items appear as 'Saved" ?
Are you sure you are publishing to the exact same folder you are looking at?
2020-04-22 09:04 AM
Could this be a problem with the folder naming maybe?
2020-04-22 10:12 AM
2020-04-22 10:56 AM
Barry wrote:
It could be.
The path may be too long as mentioned before (but then I wouldn't expect the other files to publish either).
Or maybe you have a special character in the plan name or folder?
I try to even avoid full stops in a name.
2020-04-22 11:05 AM
papsphilip wrote:Barry wrote:
It could be.
I try to even avoid full stops in a name. But you have to keep in min
Υes sometimes full stops have created problems others times again no, its weird. special characters always cause problems so i avoid those.
But i published my folders directly to the desktop and it seems to be working, all plans are there (with full stops in the titles)
2020-04-22 11:29 AM
