Publisher's PDFs are Zero kB
alexliz24
I sent these pdfs from Publisher, and the colleague said they wouldn't open. I tried to open them myself, couldn't. Then had a look at the file size: 0kB.
I eventually had to use File->Print as PDF to get the thing done.
Is this a reported bug, I wonder? Or some problem specific to my config?
Alex Zachopoulos
MacBook Pro 17" 2.4GHz, MacOS X 10.5.6, ArchiCAD 11 & 12, WinXP, Vista (well, not really Vista...)
4 REPLIES 4
Fra
see this post:
http://archicad-talk.graphisoft.com/viewtopic.php?t=12105
and my solution
Francesco
AC25 AC26 (Ita)
Mac Studio M1 Max 64 GB - OSX 12.4
alexliz24
Excellent, Francesco, it did the trick!
Just for the sake of other poor souls who are plagued by the same problem, I'll review the process here:
1. Run Software Update (from /Applications/Utilities)
2. Select the Java131and142Release2 update and install it
3. Restart ArchiCAD (although it might even work without a restart).
4. Now, publish pdfs to your heart's content through Publisher.
No more Zero kB files!
Alex Zachopoulos
Fra
After downloaded and install the Java 131 and 142 release 2, i run "Software Update" i find a Java 2 5.0 release 4
Francesco
AC25 AC26 (Ita)
alexliz24
Yes, me too. J2SE, to be precise. Donwloaded it and installed it.
Alex Zachopoulos
