2021-07-16 06:04 AM - last edited on 2023-05-19 03:44 PM by Gordana Radonic
2021-07-20 12:11 PM
2021-08-09 08:06 AM
2021-11-17 08:58 PM
Can you do a sreen shot how you did it? I am not able to published a single PDF file with autotext in it. thank you very much.
2022-08-19 08:30 AM
I think that I have found why this is not working for user who created this topic.
There is a difference for folders which are as a shortcut from the rest of project navigator (view map and layouts) and for folders that we can create manually in publisher set.
For shortcuts, the autotexts (e.g. <PROJECTNAME>) works fine, but if you put this auto text on folder which is created manually (not a shortcut) the "<PROJECTNAME>" will be exported. I've tested it on version from 23 to 26.
I`m not sure why this is happening but from my understanding there is no connection of manually created folders to the project info therefore it is not going to use the auto texts. But I don't understand why the system info (datum, time, path file etc.) are not working too.
