ā2006-07-18
07:43 PM
ā2023-05-19
10:24 PM
Gordana Radonic
ā2006-07-21 04:11 PM
ā2006-07-21 09:50 PM
ā2006-07-21 10:05 PM
Peter wrote:
Steve, the setup you show in your image appears to be the
same as my setup. Can you make a multi-page PDF of your
layout book ? If so, how do you do it ?
BTW, how do you make a .jpg of the navigator and organizer windows ?
when I try all I get is the AC window that is behind these windows.
ā2006-07-21 10:16 PM
ā2006-07-21 10:18 PM
ā2006-07-21 11:04 PM
Peter wrote:
Hello Steve,
I will check with another project.
When I hit (command+shift+3) or (command+shift+4) I get
a PDF not a .png. Curious.
Thanks,
Peter Devlin
ā2006-07-21 11:54 PM
ā2006-07-22 12:47 AM
With the setup as shown in the image I last posted,Just another save operation? Can you please expand on that? Maybe with some screenshots. Are you sure you've set your path in the Publishing Properties dialog?
if I hit "publish" I do not get a PDF but just another "save"
operation of the two layouts.
ā2006-07-22 01:41 AM
ā2006-07-22 01:54 AM
