Publishing to .plt --BIG BUG--only one page is generated
Chazz
Has anyone tried publishing to PLT? In Publisher, under Plot Settings the only choice is (confusingly) Active Layout The other choice is greyed out. What does that mean? I want to publish ALL the documents in the the publishing set. That's why I put them there --right? If you save the settings and click the publish button, Archicad grinds through all your pages but only builds a skinny little ~100k 1 page plt file. I'd be happy to have just one big multipage file, though this page proposes a way to fix create multiple 1-page files. Still, it doesn't address the problem I'm seeing here.
Anyone having any success? Please speak up.
And while were talking about it, why can't you publish your PLTs to FTP like you can with PDF? This is usually what I (and I imagine others) want to do. Thanks.
Chazz
Nattering nabob of negativism
1 REPLY 1
Djordje
How does your publishing set look?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
