Saturday
I am perplexed!!!
When I insert railings into 2d plan they show, but in 3d they do not show. Model view options all railing components are checked. I tried simplified, full detail setting as well. All layers on. Filter and cut objects, railings are checked. Every setting I've looked at the railings are not turned off. Any help would be Greatly appreciated. Thankyou
Operating system used: Windows 23H2
yesterday
So if you select the railing in plan and then right click and 'show in 3D', do you see it then?
yesterday
Is there any chance that you are using different view settings between 2d and 3d that might made the railings not visible (layer off for example)
Or having the railings disabled in the "3d filter and cut elements "options????
