Red Morph on floorplan
ari_brick
I am making a simple volume model with a bunch of morphs and pasting it into an existing model. most of this was built in rhino. I have turned everything into morphs and changed every attribute i could find on all morphs to the same thing, but the morphs I constructed in archicad itself still display as red on the floorplan whereas the morphs imported from rhino are displayed as white. This results in the archicad morphs having a hatch when i print this plan.
How do i change the archicad morphs to not have this red infill on the plans & layouts?
ari_brick
Alright i found out how to remove the fill. It's in Morph Selection Settings. Took me an hour to find that haha
1 REPLY 1
ari_brick
