cocoloco
Remove background from LOGO (layouts)
Hi! Some of our layouts include visuals only on the page and want to show only LOGO (over the visuals). I have all kinds of files but archicad seem to only show the logo no matter what with background . This is 2024. Archicad doesn't have feature that would upload png or other files, WITHOUT BACKGROUND?
Again. the goal is to spread the visuals over layout but have logo still show. Obviously, it looks really stupid with the logo with white background over it . You can only imagine 😄
Please is there some plugin or workaround that would enable this feature, to hide background when there is none?
Operating system used: Mac Apple Silicon new
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
2 Solutions
If I bring a logo in using the 'drawing' tool (the logo is just a JPG file with a white background) and I bring to the front display order, it will cover all that is behind it.
But if I now set that 'drawing' to have a transparent background, the white disappears.
This doesn't matter if I do this in the plan window or on a layout page.
How are you placing your logo on the layout?
Does your logo have a white background?
Barry
Go to post
scottjm
Mentor
There is a setting in the master layout settings as to whether content on a master is displayed above or below the content in the layout sheet. Set this to above.
Go to post
6 Replies 6
Barry
cocoloco
Edit: @Barry Kelly This worked, thank you! However when I now place the logo in master layout, it shows BEHIND the photos.... I tried to change "display order" but it didnt change either. (The point is for me that I can spread the renderings on page as I want, and the logo shows ON TOP of it ?
scottjm
Mentor
cocoloco
thank you found it! 🙈
Lingwisyer
Guru
The only issue with the "Transparent" setting is that it just makes anything white transparent rather than using the alpha channel.
Ling.
cocoloco
yeah I was excited but them the logo that turned white into transparency left white around the brand letters noticeable on top of visual 😩🙈😂🔥🔥 looks like I just started using photoshop lol
