Johann_P
Remove decal in Twinmotion
I'm not sure if this forum is the correct place to ask this...
I have some decals that has been applied in Twinmotion.
The model has changed and I now want to remove some decals and relocate others, but I cant seem to select the decals in Twinmotion.
How do I select/delete them?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 Solution
jfaugustine
 On the righthand side of the workspace in Twinmotion, there is a list of components added to a project.   By default, the components are listed in chronological order as added to the project.  There are also filter switches at the top of the panel to reduce the search effort.  Once the decals are identified they can be turned off or deleted.
ArchiCAD since 8.0, currently on 22, waiting on 26, maybe...
Go to post
4 Replies 4
If it was done in Twinmotion, then it is probably best to ask in a Twinmotion forum.
Djordje
TM Forum is on Facebook and their portals.
BTW, just delete the decal... anyway they still don't show if PathTracing is on
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
jfaugustine
Johann_P
Thanks. I used the righthand side workspace as you suggested and now renamed the relevant components for future.
Windows 10 Pro
