I finally figured out which pens are determining the pen weights that show in the "To be demolished" status.
It's kind of tricky.
Each of the Composite walls in my example reads the pen weight from different sources.
The first one – entire wall "To be demolished" – reads the pen weight from the out most contour pen defined in the Composite Settings (actually it reads all countour, but only the out most matters, because the other are hidden below the overwritten fill).
The second one – a "New" opening in an "Existing" wall (i.e., the "To be demolished" portion of the wall)– reads the pen weight from Floor Plan and Section > Cut Surfaces > Cut Line Pen.
But you don't have direct access to the Cut Line Pen setting, because it is a composite wall. So you have to change the wall to Basic (instead of Composite), change the Cut Line Pen, hit OK, then edit the wall again and change it back to Composite!
