2016-06-09
07:17 PM
2023-05-26
02:11 AM
Gordana Radonic
2016-06-16 12:00 AM
2016-06-16 03:09 AM
2016-06-16 08:51 AM
2016-06-16 03:03 PM
rob2218 wrote:•01• Wall_A_Existing and SEO'd with Upwards extrusion to Roof_Existing
yes..I'm fully aware that once a "real" roof is removed, it leaves a gap. thank you for clearing that up.
Now, explain the solid element operation function because I have tried that. I've tried to to SEO from one wall to another and it behaves very strangely.
So, I'd like your explanation of how to accomplish this?
another Moderator
2016-06-16 03:50 PM
rob2218 wrote:I am sorry, Rob, for coming across as a condescending jerk.
yes..I'm fully aware that once a "real" roof is removed, it leaves a gap. thank you for clearing that up.?
Erwin wrote:It depends on your approach. If I where to do a project in ARCHICAD I would use it as a VCS (Virtual Construction Simulation) platform breaking the future building into real-life-related demolition/renovation/construction processes rather than 2D drawings of the future building. I have a very odd attitude to this, but I believe that with a proper setup and approach ARCHICAD user can eliminate any 2D drafting what so ever.
Unless you need super accurate 3d demolished views, why not just offset the existing wall and add a new one to the end?
It is possible to put a small bit of wall there and use one of the triangular opening windows to cut away the bit where the roof is, if you want to be super precise, but it is unlikely to be build like that too.
rob2218 wrote:Rob, there are many ways to skin the cat, and I am by no means an example, but since you are asking about my process I would explain it (we are not talking about filling in an empty triangle space under your roof, as that was answered by
