Renovation lines
Mac_the_arc
Im preparing planning drawings for a house extension and have created a slapping through an existing external wall for the new extension. The wall and roof eaves to be removed has been put on a demolition status, however when viewing the 'existing elevations', this wall has lines that I dont want to see between the 'existing and demolition' renovation status. How do I hide these.
8 REPLIES 8
I am not sure what a "slapping" is.
Do the exiting and to be demolished walls overlap at all or just touch end to end as they should?
Is the to be demolished items set to 'Show' and any new items set to 'Hidden' in the show existing renovation filter?
If you set the "Show All' filter on, do you see the same thing?
Mac_the_arc
a slapping is an opening in an existing wall, it must be a Scottish building term.
Wall ends touch. The demolished filter is set to show. If I set this to hide then I just get a gaping hole on the existing drawings. Show All just turns on the new elements.
Must be.
So have you placed an actual opening in the wall?
No need, just split the existing wall and then set the part that is to go as 'to be demolished'.
So back to my original question. I have an existing wall (existing filter), which I have split to create a slapping putting the wall I want to remove onto the demolition filter. When I create an existing elevation of the wall, I can see the lines between the two filters. I can't find a way in AC to hide these lines, and as a fix im having to use hatches t cover them.
Exactly what I did.
Can you drag a copy of just those 3 walls to the side and have a look at them?
I was wondering if something else is interfering.
Mac_the_arc
I have tried this, and you can see the lines. Interestingly they dont appear in the 3d window but do on plan.
I have even tried drawing a completely new wall then cutting and changing renovation status and still the lines appear between existing and demolished.
Guru
Check that your Renovation Filter is allowing your to be demolished elements to join with existing elements.
The 3D window does not care about intersections, as long as things are the same Surface and are co-planar...
Ling.
Thanks and both existing and demolished 'Do not intersect boxes' are unticked and still lines appear.
