Renovation - wall composite layer delete/add
is it possible to use renovation as demolition some wall elements and add new wall elements(layers) ?
renovation is mainly adding insulation to building..
Unfortunately no, Renovation Filters are always affecting the whole element.
Erwin Edel
I ended up modelling the insulation seperately last time around, but there was no demolishing of the existing facade underneath. There were some minor issues with two walls touching and archicad interpreting the cutlines where they touch as skin seperators, mostly to do with how we override the model views (graphic overrides / renovation filter settings).
Wall holes and wall niches sometimes help with 'demolishing' partial bits of walls. Just place these as 'new' elements and they will show up as bits that need to be demolished.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
