Andrew Swenson
Renovations & Phases
Ok so I've migrated a project from v14 to v15 and taken advantage on the Renovation phases to better organise the redevelopment work required on a medium scale project.
Now the client has asked that I produce phasing plans. I did some searching and found some ideas of using module files which seemed to work until I got to the point of putting the modules back into the existing file and tried to set up the stage 2 phasing drawings.
Obviously I've run into the the problem that the stage 1 demolition items are showing in the stage 2 demolition when I need to show the stage 1 new works along side the stage 2 demolition works.
I'm thinking I'm going to have to create separate existing, demolition & new layers for each stage to work in conjunction with the Renovation staging of v15.
But I thought I would see what other ideas might be out there!!
I did add my vote to the Renovation and Phasing wish
ArchiCAD 5.1 - 24
MSI WS63 8SL
Intel i7-8850K @ 2.60GHz
32Gb RAM
Windows 10 Pro 64bit
TwinMotion 2020.2
0 Replies 0
